18 years agoUsing DE2 board with Quartus and NIOS IDE Version 8
Hello, I've installed Quartus Version 8 and NIOS IDE Version 8 after using Version 7 for some time. With version 7, there was no problem in using the DE2 board with NIOS IDE - everything worked...
18 years agoDid you try re-generating (and compiling) the SOPC system and then compiling and using your old projects? Simply importing old projects in the new version without recompiling the SOPC system will not work.
