17 years agousing DE1 control panel to put colour images into SRAM
i have been trying to put images into SRAM using the DE1 control panel.. so far, i hv been able to show a grayscale picture in VGA to an external monitor... but when i tried it with a colour ...
10 years agoSpecifically where will the image data be stored after we capture the image? In the DE1_D5M camera module, after capturing the image, it will be converted to RGB thru RAW2RGB module right? Then from there, will it be stored to SDRAM? I wanted to make the image be shown in grayscale. I have the code but I am not sure if I'm getting the right image data and if I'm outputting the right image data and address as well.
