17 years agoUSB Without NIOS
Is anyone aware of some sample HDL code that accesses the DE2 USB chip (ISP1362) as a Device WITHOUT NIOS or any other processor implementation? In other words, by just programming a Verilog or VHDL ...
14 years ago --- Quote Start --- First of all, thanks for your response! Unfortunately your driver which you are providing does not work on windows7 64 bit. Can I use the driver from libusb? fisa --- Quote End --- I have tested it to work under Windows 7 64bit SP1. You can try re-generating the driver from libusb-win32. Good luck!
