17 years agoUSB Without NIOS
Is anyone aware of some sample HDL code that accesses the DE2 USB chip (ISP1362) as a Device WITHOUT NIOS or any other processor implementation? In other words, by just programming a Verilog or VHDL ...
14 years ago --- Quote Start --- Ok - I assume that after you load the fpga image to the board, and connect the USB cable, you get the familiar 'USB device not recognized' balloon message in the task bar. To solve this - you would need to 'install the driver manually'. Here is the tutorial on how to do that: --- Quote End --- First of all, thanks for your response! Unfortunately your driver which you are providing does not work on windows7 64 bit. Can I use the driver from libusb? fisa
