15 years agoUPDS v11.0 Altera Monitor Program Tutorial Compilation Error
I'm trying to complete the Altera Monitor Tutorial which is included with Altera Monitor Program (UPDS v.11.0) for Quartus II ver 11.0. When I try to "compile and load" the project as instructed in ...
15 years ago --- Quote Start --- I'm trying to complete the Altera Monitor Tutorial which is included with Altera Monitor Program (UPDS v.11.0) for Quartus II ver 11.0. When I try to "compile and load" the project as instructed in the tutorial I receive the following errors: compiling source files...
nios2-elf-as --gstabs -i c:/altera/11.0/nios2eds/components/altera_nios2/sdk/inc -i c:/monitor_tutorial c:/monitor_tutorial/getting_started.s -o c:/monitor_tutorial/getting_started.s.o
/usr/bin/bash: nios2-elf-as: command not found
linking...
nios2-elf-ld --defsym nasys_program_mem=0x0 --defsym nasys_data_mem=0x0 --section-start .exceptions=0x20 --section-start .reset=0x0 -e _start -u _start --script c:/altera/11.0/quartus/../university_program/monitor_program/build/nios_as_build.ld -g -o c:/monitor_tutorial/getting_started.elf c:/monitor_tutorial/getting_started.s.o
/usr/bin/bash: nios2-elf-ld: command not found
compilation stopped. If I run the above commands in the NIOS II Command Shell, the program compiles and runs without any issue. Is there something I can do to make the Altera Monitor Program perform as intended or is there something inherently broken with this version of the Altera Monitor Program? I don't know if this is relevant or not, but I'm running Quartus and the Altera Monitor Program on Windows XP Pro SP3. --- Quote End --- I've exactly the same problem since I moved to Quartus II version 11. I reinstalled the University package e tried to mix up with the path variable, but I couldn't fix the problem. Any suggestion? Thanks for your cooperation, fb
