16 years agoUPDS Installation Error
I keep getting an error that says "Altera University Program Design Suite requires Nios II to be installed." I have already installed Quartus II 10.0 and Nios II EDS 10.0 as instructed. I also...
16 years agoEach release of the UPDS requires a specific version of the QII and Nios II installations. It sounds like the version you are using requires Q II 9.0 sp2. To download this version, do to the Download Center on altera.com and look under Archives (on the left side of the page) to find the required version. When you first run the version after installation, it should set the environment variable called QUARTUS _ROOTDIR, which is the variable checked by the UPDS installer.
