16 years agoUP VGA Pixel Buffer problem
Hello, I'm trying to use vga pixel buffer as a data source for the vga controller in SOPC builder on a DE2 board using Quartus 9.1. I'm not really sure what I need to use with the pixel bu...
12 years agoThanks ronix for posting that. I can compile the Verilog part of it, but what do you do with the C program? Is it compiled with the Altera Monitor program? I don't see an ncf file which it would read...?
Thanks for any help! Tom --- Quote Start --- Hello renaudberube! Thx for your reply! I found out what was wrong - I made some terrible mistake while adding sdram to my project (used output instead of bidirectional pin). Now everything is working like a charm :) Anyway many thx for your concern :) Regards @speak48 Probably you pixel buffer device has different name in your sopc system, maybe "pixel_buffer_0" or something like that... Many people have problems with this VGA stuff, so I attached some basic project including pixel buffer and simple software that draws some garbage on the screen. Hope some of You will find that useful. Project is for DE-2 board --- Quote End ---
