16 years agoUP VGA Pixel Buffer problem
Hello, I'm trying to use vga pixel buffer as a data source for the vga controller in SOPC builder on a DE2 board using Quartus 9.1. I'm not really sure what I need to use with the pixel bu...
16 years agoi have some questions
i'm a bit confused with the relationship between the pixel buffer and the sdram 1. does the sdram act as the buffer which is controlled with the pixel buffer?? 2. does the "default buffer start address" in the configuration of the pixel buffer refer to the base address of the sdram controller?? i have attached the picture showing the connection between the sdram and the pixel buffer
