16 years agoUP VGA Pixel Buffer problem
Hello, I'm trying to use vga pixel buffer as a data source for the vga controller in SOPC builder on a DE2 board using Quartus 9.1. I'm not really sure what I need to use with the pixel bu...
16 years agoThanks a lot ronix5000 :)
I found my mistake finally.I generated 640*480 vga signal but first it took about 1000-2000ms to change all screen (100 Mhz nios core) and then I have made some modifications which reduce it to 117 ms (max. 9 fps).it is still not enough.I mean it looks like impossible to play a real-time video. Can this problem be handled somehow or should I change the video out core ?
