13 years agoUP SD card IP core compatibility
Hello, I'm using the altera NEEK, cyclone III (3C25 FPGA) edition with the SD card included (used in the application selector example). I have added University SD card IP core in quartus 12.1 (u...
13 years agoHi,
I am using SD Card University IP core with a DE board. I have two SD cards a 128MB and a 2GB, but none is working with the core. The cards are detected but the function alt_up_sd_card_is_FAT16() returns a wrong result. I have tested with a simple program: # define READ_BLOCK 17 int main(void) { int *command_argument_register = ((int *)(0x0100122C)); short int *command_register = ((short int *)(0x01001230)); short int *aux_status_register = ((short int *)(0x01001234)); short int status; /* Wait for the SD Card to be connected to the SD Card Port. */ do { status = (short int) IORD_16DIRECT(aux_status_register, 0); } while ((status & 0x02) == 0); /* Read 11th sector on the card */ IOWR_32DIRECT(command_argument_register, 0, (10) * 512); IOWR_16DIRECT(command_register, 0, READ_BLOCK); /* Wait until the operation completes. */ do { status = (short int) IORD_16DIRECT(aux_status_register, 0); } while ((status & 0x04)!=0); } but the aux_status_register indicates a read error on bit 5. My hardware is configured as shown below(VHDL): NiosII: nios_system PORT MAP ( b_SD_cmd_to_and_from_the_SDCard_Interface => SD_CMD, b_SD_dat3_to_and_from_the_SDCard_Interface => SD_DAT3, b_SD_dat_to_and_from_the_SDCard_Interface => SD_DAT, o_SD_clock_from_the_SDCard_Interface => SD_CLK, out_port_from_the_Display => count, out_port_from_the_LEDs => LEDG, zs_addr_from_the_sdram_0 => DRAM_ADDR, zs_ba_from_the_sdram_0 => DRAM_BA, zs_cas_n_from_the_sdram_0 => DRAM_CAS_N, zs_cke_from_the_sdram_0 => DRAM_CKE, zs_cs_n_from_the_sdram_0 => DRAM_CS_N, zs_dq_to_and_from_the_sdram_0 => DRAM_DQ, zs_dqm_from_the_sdram_0 => DRAM_DQM, zs_ras_n_from_the_sdram_0 => DRAM_RAS_N, zs_we_n_from_the_sdram_0 => DRAM_WE_N, clk_0 => CLOCK_CPU, reset_n => pll_locked and KEY(0) );
