10 years agoUniversity program vwf
hello
i have 3 verilog files and three vwf file correspond to the verilog file ex: first.v, second.v, third.v, first.vwf, second.vwf, third.vwf i know that if i want to run simulation on one of the vwf file, i have to set it to top entity. ex: if i want to run simulation on third.vwf, i need to set third to top entity. The first and second vwf window that showed up was correct but when i try to run the third, it showed up the second vwf window even though i already set third to top entity. Can i know where is the problem and how do i fix it so that come up with correct window. p/s:third is the module that combine first and secondNo RepliesBe the first to reply
