18 years agoUniversity Program IP Cores and Quartus II 7.2
Hello, I'm using the DE2 board and installed the new University Program IP Cores. I'm also using Quartus II 7.2. When I'm add DE Boards External Interface to my nios 2 and select for examp...
18 years agoHi !
I have used VGA Core but I don't control VGA monitor. can you help me? module vgacontroller ( KEY, CLOCK_50, DRAM_CLK, DRAM_CKE, DRAM_ADDR, DRAM_BA_1, DRAM_BA_0, DRAM_CS_N, DRAM_CAS_N, DRAM_RAS_N, DRAM_WE_N, DRAM_DQ, DRAM_UDQM, DRAM_LDQM, SRAM_ADDR, SRAM_CE_N, SRAM_DQ, SRAM_LB_N, SRAM_OE_N, SRAM_UB_N, SRAM_WE_N, //////////////////// VGA //////////////////////////// VGA_CLK, // VGA Clock VGA_HS, // VGA H_SYNC VGA_VS, // VGA V_SYNC VGA_BLANK, // VGA BLANK VGA_SYNC, // VGA SYNC VGA_R, // VGA Red[9:0] VGA_G, // VGA Green[9:0] VGA_B, // VGA Blue[9:0] ); input [0:0] KEY; input CLOCK_50; output [11:0] DRAM_ADDR; output DRAM_BA_1, DRAM_BA_0, DRAM_CAS_N, DRAM_RAS_N, DRAM_CLK; output DRAM_CKE, DRAM_CS_N, DRAM_WE_N, DRAM_UDQM, DRAM_LDQM; inout [15:0] DRAM_DQ; wire CLOCK_25; inout [15:0] SRAM_DQ; // SRAM Data bus 16 Bits output [17:0] SRAM_ADDR; // SRAM Address bus 18 Bits output SRAM_UB_N; // SRAM Low-byte Data Mask output SRAM_LB_N; // SRAM High-byte Data Mask output SRAM_WE_N; // SRAM Write Enable output SRAM_CE_N; // SRAM Chip Enable output SRAM_OE_N; //////////////////////// VGA //////////////////////////// output VGA_CLK; // VGA Clock output VGA_HS; // VGA H_SYNC output VGA_VS; // VGA V_SYNC output VGA_BLANK; // VGA BLANK output VGA_SYNC; // VGA SYNC output [9:0] VGA_R; // VGA Red[9:0] output [9:0] VGA_G; // VGA Green[9:0] output [9:0] VGA_B; // VGA Blue[9:0] // Instantiate the Nios II system module generated by the SOPC Builder nios_system NiosII ( CLOCK_50, CLOCK_25, KEY[0], DRAM_ADDR, {DRAM_BA_1, DRAM_BA_0}, DRAM_CAS_N, DRAM_CKE, DRAM_CS_N, DRAM_DQ, {DRAM_UDQM, DRAM_LDQM}, DRAM_RAS_N, DRAM_WE_N, SRAM_ADDR, SRAM_CE_N, SRAM_DQ, SRAM_LB_N, SRAM_OE_N, SRAM_UB_N, SRAM_WE_N, VGA_BLANK, VGA_B, VGA_G, VGA_HS, VGA_R, VGA_SYNC, VGA_VS ); // Instantiate the module sdram_pll (inclk0, c0) sdram_pll neg_3ns (CLOCK_50, DRAM_CLK,CLOCK_25,VGA_CLK); endmodule http://img501.imageshack.us/my.php?image=thuzr3.png
