17 years agoUniversity IP doesn't appear in SOPC builder 9.0 sp1
Hi, I installed the university IP but I can't see these cores in SOPC builder. I have QuartusII 9.0 sp1 installed. Do you have any idea why it doesn't appear? Thanks..
17 years agoI did it already before posting the link. It works, at least it allows me to select baud rate and the rest of the parameters. Because of that I thought that maybe you were not using 9.0 cores.
The only question is that I'm working on linux with Quartus 9.0 without SP1 (which is not available in linux, or I did not found it). So, It is only a windows related problem, a SP1 problem or something special in your system. One last warning, I suppose you "refreshed" your SOPC system when changing IP cores versions, did you?
