15 years agoUniversity IP : Audio Core
I'm trying to test the Audio CODEC on DE2 Board. I used Up_Avalon_Audio Core (from University IP Core, version 8.1) to building a system on NIOS II (using the Quartus 10.0sp1 Web Edition). Then, i...
15 years agoI am having the same issue with the 90 version of the University IP Core. Was there a solution to this?
my audio core is called "audio_0" in SOPC and "/dev/audio_0" does not work neither does using the "AUDIO_0_NAME"# defined in system.h Thanks
