8 years agoUART with NIOS II on DE0 Nano
Hi, I'm having trouble establishing communication between my DE0 Nano and my computer. I'm trying to do this using an FTDI usb to TTL chip (FT232R) and using the Platform Designer to create a UART I...
8 years agoYour pictures are too small to see anything.
Did you use the .sopcinfo file from Qsys (Platform Designer) to generate a BSP project? This generates a header file that has macros you should use for accessing the correct addresses of components in the system.
