THuyn18
6 years agoTrouble with programming EPCQ via JTAG interface, cannot find flash loader.
Hello, I am trying to program an EPCQ4A through an FPGA (10CL006ZE144). When I go to create the .jic file, the flash loader for my FPGA is not listed. The closest I can find is 10CL006Z, and when I...
ShafiqY_Intel
6 years agoHi THuyn18,
Have you check your MSEL pin? Did you set it to AS config?
I afraid you are not set MSEL Pin as Active Serial (AS) configuration.
Am I supposed to recreate the jic file after changing the frequency?
No, you no need to change the .jic file.
