THuyn18
6 years agoTrouble with programming EPCQ via JTAG interface, cannot find flash loader.
Hello, I am trying to program an EPCQ4A through an FPGA (10CL006ZE144). When I go to create the .jic file, the flash loader for my FPGA is not listed. The closest I can find is 10CL006Z, and when I...
a_x_h_75
Contributor
6 years agoThat's the correct device to select when creating your jic file.
What hardware are you using? Given the device you specify I guess it's your own custom hardware.
Can you program the FPGA directly, using the sof, via JTAG? I think this is more likely to be a signal integrity issue.
Cheers,
Alex
- THuyn186 years ago
Hi Alex,
I'm using the USB Blaster II, and I can program the FPGA with a .sof without any issues.
Tin
After taking another look at my board schematic, I noticed that the 3 MSEL pins are grounded. Could this be the problem? I remember reading somewhere that the FPGA must be set to active serial to program an EPCQ device, but I'm not sure where.
