Triple speed Ethernet (TSE) MAC Configuration in 10/100 for Arria 10 device FPGA.
Hello ,
Am Working on ARRIA 10 device FPGA (10AX016E3F27I2SG) . Using Quartus Standard edition version 21.1 for FPGA Design and NIOS II SDK Tool for Software development. Designed custom board embedded with this FPGA connect to Ethernet PHY(KSZ8081RNDCA-TR) . I have created a project in Nios II SDK Tool where Board support Package ( BSP )Files generated .
Am referring this file ug_ethernet-683402-666815%20(3).pdf . to work on ethernet.
1. I have gone through the function descriptions of page 195 ( tse_mac_raw_send() ). But, this function is not available in the NIOS II tool generated BSP Files. And we need tse_mac_raw_Receive function also which is not available.
2. Can you please give the MAC INITIALIZATION and PHY Management sequence or drivers .
3. Is there any special effort required to update ethernet driver ?
I have attached all the BSP Files related to ethernet ,which got generated in Nios II tool. Can you please tell us that these files are usefull or not .If it is ,then send the sequence process to work on ethernet driver.
Thanks in advance , we are expecting fast response as we are in urgent need of this ethernet.
Thanks & regards ,
Deepa.G
