The problem with the simulation.
Hello. I have a problem with the simulation. Quartus 13.1 web edition.( my teacher at the University is a member of the FPGA University program)
For my thesis work requires muster receiver and transmitter on asi interface. The latest version of megafunction support is 13.1. I can't test the performance of the assembled circuit on the simulator. My Board de0-nano cyclone 4e. Attach a file with the project.
- RichardT_altera
I checked your project and it seems the ASI IP is EOL. Unfortunately, there is no more technical support for this IP. I have attached a list of currently supported video IP and if you plan to change to one of them, we gladly help you. I will proceed to close this case and please file another case if you have further inquiry on the supported video IP.
If you wish to use the current ASI IP, you can refer to the reference manual attached.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_asi.pdf
- ISush
I know that this interface is no longer being updated. But I need it, because the installation uses this interface. Can I get a license for this? - RichardT_altera
You can get the license from the Self Service Licensing Center.
