13 years agoTest-Pattern Generator IP from Altera University Program (UP) Video IP cores issues.
Did anyone tried to use Test-Pattern Generator IP from Altera University Program (UP) Video IP cores?
Does it produce still or moving picture? What is the maximum clock and Frame Resolution? I tried 1920x1080 @ 148,5 MHz, but Test-Pattern Generator IP did not produce anything valid according to Signal Tap II...15 Replies
And thank you for the link, but I think a wrapping of this code takes longer than writing your own one.
For this complexity of TestPattern this should not be more than 2 days of work... - Altera_Forum
--- Quote Start --- Ah, one more thing. You have connected the reset input from the TPG to GND, but in the bdf the reset input looks like reset_n, what would say, that your TPG is always in the reset... Check this please! --- Quote End --- That`s right! I followed the style of Reset in VIP TPG and overlooked , that UP TPG had a Reset of negative polarity. Now its OK! - Altera_Forum
--- Quote Start --- And thank you for the link, but I think a wrapping of this code takes longer than writing your own one. For this complexity of TestPattern this should not be more than 2 days of work... --- Quote End --- OK, I'll wait for some time for the response from the author and if no reply then will try to adapt it by myself. - Altera_Forum
Taz1984, thank You for Your help!
No Problem, if you have further questions do not hesitate to ask... :)
