13 years ago
Test-Pattern Generator IP from Altera University Program (UP) Video IP cores issues.
Did anyone tried to use Test-Pattern Generator IP from Altera University Program (UP) Video IP cores?
Does it produce still or moving picture?
What is the maximum clock and Frame Resolution?
I tried 1920x1080 @ 148,5 MHz, but Test-Pattern Generator IP did not produce anything valid according to Signal Tap II...
    And thank you for the link, but I think a wrapping of this code takes longer than writing your own one.
    For this complexity of TestPattern this should not be more than 2 days of work...
    --- Quote Start ---
    Ah, one more thing.
    You have connected the reset input from the TPG to GND, but in the bdf the reset input looks like reset_n, what would say, that your TPG is always in the reset...
    Check this please!
    --- Quote End ---
    That`s right! I followed the style of Reset in VIP TPG and overlooked , that UP TPG had a Reset of negative polarity.
    Now its OK!
    --- Quote Start ---
    --- Quote End ---
    OK, I'll wait for some time for the response from the author and if no reply then will try to adapt it by myself.
    No Problem, if you have further questions do not hesitate to ask... :)
