13 years agoTest-Pattern Generator IP from Altera University Program (UP) Video IP cores issues.
Did anyone tried to use Test-Pattern Generator IP from Altera University Program (UP) Video IP cores? Does it produce still or moving picture? What is the maximum clock and Frame Resolution? I...
13 years agoTrigger conditions from the SignalTap Setup-Page are in default setting - the same I used when examining TPG from VIP.
https://www.alteraforum.com/forum/attachment.php?attachmentid=7370 --- Quote Start --- And I've not seen any TPG with moving colorbars, sorry. If I need one in future, I will write me one... =) --- Quote End --- I have source code of TPG with moving colorbars from Opencores, but it needs to be adapted to be able to be connected to Altera Avalon-ST because then I need to connect it to Altera Clocked Video Output IP ( from VIP ). If You are interested, I could post it here or here is a direct link: http://opencores.org/project,patterngen,overview Maybe You or someone could help to make this kind of adaptation.
