13 years agoTest-Pattern Generator IP from Altera University Program (UP) Video IP cores issues.
Did anyone tried to use Test-Pattern Generator IP from Altera University Program (UP) Video IP cores? Does it produce still or moving picture? What is the maximum clock and Frame Resolution? I...
13 years agoLike in [1] declared, you need to set ready to one, to start the data transfer, or to stop it.
So I advice you to red [1]. Because of, that I think that the TPG is similar to the one of the Video Image Processing (VIP) Suite, I also post the link of the VIP-Spec in [2]. In [2] there is also a section about the Avalon-ST datatransfer. So my advice is to read this first and if you need a deeper detail, read [1]... [1] http://www.altera.com/literature/manual/mnl_avalon_spec.pdf [2] http://www.altera.com/literature/ug/ug_vip.pdf
