13 years agoTest-Pattern Generator IP from Altera University Program (UP) Video IP cores issues.
Did anyone tried to use Test-Pattern Generator IP from Altera University Program (UP) Video IP cores? Does it produce still or moving picture? What is the maximum clock and Frame Resolution? I...
13 years agoHere is BDF screenshot attached.
https://www.alteraforum.com/forum/attachment.php?attachmentid=7365 Did You mean, that I should use "video_test_pattern_0_avalon_generator_source_ready" ? I now noticed, that it is an input, although it is located on the output side of TPG BSF block. But leaving it unconnected or connecting in to "1" makes no difference. With Signal Tap II I see: https://www.alteraforum.com/forum/attachment.php?attachmentid=7366 Are You sure, that Test-Pattern Generator IP from Altera University Program can produce colorbars? Did You try it by Yourself? Can You advise any TPG with moving colorbars?
