Terasic De10-Nano tutorial source code down
O.k. you are looking specifically for the "On-board Accelerometer Tutorial" project which is apparently not included with the DE10-Nano CDROM. You can ask Terasic support if they have it.
That's fine thank you. Anyway, I'm just trying to get my board to have internet access. From what I read in the getting started guide , I should be able to use a micro B USB to tunnel Ethernet from my laptop to the board. I installed RNDIS on windows, was able to access the local server 192.168.7.1 and all. Then I connected to the board via terminal ssh and tried to ping my laptop but it didn't work. From my research the board and my laptop has to exist in the same subnet? So I tried to change the IP, mask, gateway on my laptop at first, then on the board, neither worked.
Can you let me know if I'm doing it right? How do I get internet access via micro B USB
