11 years agoTERASIC board warranty issues, beware
I want to warn fellow engineers about an issue I had with Terasic. I purchased a DE1 board from them and it promptly failed after using it only for 2 weeks. All I did with the board was turn it on ...
11 years agoHi Kuchinn,
--- Quote Start --- Actually, after having personally done 10 production ASIC designs and 2 dozen production FPGA designs, I only recall one FPGA being destroyed due to mis-programming. --- Quote End --- Ok, so you know what you are doing then. Assuming your board did not fail due to misprogramming and destroying the FPGA, were you able to determine what stopped working on your DE1 board? Perhaps it is something simple like a failed power supply. I think if you were able to identify a fault in your board Terasic would be willing to fix it. Cheers, Dave
