17 years agoTCP/IP on Altera DE2 How to??
Hello, I have been battling with this problem for quite some time so any help will be appreciated! Basically, I am trying to create possibility of communication between Host PC and DE2 via Ethernet f...
17 years agommmmm, you've ever used uClinux?. If you did, this is a good option. The web has a lot of examples about using linux sockets. This could be helpful in that case http://www.nioswiki.com/operatingsystems/uclinux/ethernet
