17 years agoTCP/IP on Altera DE2 How to??
Hello, I have been battling with this problem for quite some time so any help will be appreciated! Basically, I am trying to create possibility of communication between Host PC and DE2 via Ethernet f...
17 years agoThanks so much for the quick reply!
So if I got it right, these are the steps: 1) take the Terrassic DM9000A component from DE2_Net and include it in the SOPC builder (this is what I have done when I saw Ethernet transmit something with DE2_net example) 2) use the Micrium drivers for Nios 2 IDE to use with DM9000A (and not the standard drivers) 3) Install Micrium TCP/IP and try to build around that Questions: 1) Does the Micrium TCP/IP provide some examples? (I am about to install it now) 2) Which version of Quartus+Nios would you recommend to use? Again, thanks so much for your help!
