17 years agoTCP/IP on Altera DE2 How to??
Hello, I have been battling with this problem for quite some time so any help will be appreciated! Basically, I am trying to create possibility of communication between Host PC and DE2 via Ethernet f...
17 years agoMicrium has the TCP/IP Stack (http://www.micrium.com/php/download.php?file=micrium-uc-tcp-ip.exe) and the DM9000A driver (http://www.micrium.com/php/download.php?file=micrium_nic_dm9000a.zip). By a simple registration (http://www.micrium.com/php/register.php), you can download the source code for a 45 days evaluation. I suggest you work with the TERASIS_DM9000A from DE2_NET demonstration. It could take a while but with good results. You can use the uC/OS-II downloading it from Micrium.
