18 years agoTaking image as input
Hello friends.....i am trying to do image processing using DE2 board in verilog hdl and i had written the code...but i got stucked at taking image as input and to load it into the memory on the board...
18 years ago1) double-click in a free area of your bdf file where you want to insert the altsyncram
2) a window will open up 3) in the field "Name:" (left side of the window) write down "altsyncram" and automatically the Altsyncram symbol will appear on the right side 4) tick "launch MegaWizard plug-in" and press OK 5) follow the instructions of the wizard 6) at page 3 of 12 of the wizard select "with one read port (ROM mode)" 7) at page 10 of 12 you can select the .mif file format or the .hex format
