18 years agoTaking image as input
Hello friends.....i am trying to do image processing using DE2 board in verilog hdl and i had written the code...but i got stucked at taking image as input and to load it into the memory on the board...
18 years agoI agree with parrado, and another way could be to instantiate an ALTSYNCRAM block and use it as a ROM (it is a possibility offered by the MegaWizard). The ROM should be initialized by a MIF file and the ROM cells should be read sequentially by building a simple external verilog code that generates the addresses that are sent to the read_addr port of the ALTSYNCRAM block.
It is a simple job, just try it out and tell us if you encounter problems.
