Syntax in the instantiation of a component
- 7 years ago
Hi ,
Sorry for the late reply,
For Modelsim you have to Load ALTERA_MF library.
vsim -L altera_mf -L work rs232coincidencecounter
Which Should remove the ** Warning: (vsim-3473) Component instance "LC : LCELL" is not bound.
Attached the transcript.
Anand
Check port or generic are matching between instantiation and component.
Compile all component file in modelsim instead of compiling only top file.
If possible share the project and modelsim transcript.
Anand
There are no generic ports in this file, and all component ports have an instantiated port map, though the signal names don't match exactly. For example, here's the LCELL component and its instantiation:
COMPONENT LCELL
PORT (
a_in : IN STD_LOGIC;
a_out : OUT STD_LOGIC);
END COMPONENT;
-- This creates, using iteration, a chain of LCELL buffers for each A, B, C, D signal,
-- which act to delay the signals.
LCA_1: LCELL PORT MAP(a_in=> A, a_out=>A_internal(0));
Gen_delay_A : FOR i in 0 to 23 GENERATE
LC : LCELL PORT MAP(a_in => A_internal(i), a_out => A_internal(i+1));
END GENERATE;
LCB_1: LCELL PORT MAP(a_in=> B, a_out=>B_internal(0));
Gen_delay_B : FOR i in 0 to 23 GENERATE
LC : LCELL PORT MAP(a_in => B_internal(i), a_out => B_internal(i+1));
END GENERATE;
LCC_1: LCELL PORT MAP(a_in=> C, a_out => C_internal(0));
Gen_delay_C : FOR i in 0 to 23 GENERATE
LC : LCELL PORT MAP(a_in => C_internal(i), a_out => C_internal(i+1));
END GENERATE;
LCD_1: LCELL PORT MAP(a_in=> D, a_out => D_internal(0));
Gen_delay_D : FOR i in 0 to 23 GENERATE
LC : LCELL PORT MAP(a_in => D_internal(i), a_out => D_internal(i+1));
END GENERATE;As for the component files, whenever I add a file to the project, the only folder it allows me to add it to is the "Top Level" folder, I don't know if that's significant.
The attached file is the (actual) top level code. Thanks again.
- AnandRaj_S_Intel7 years ago
Hi @OMaga ,
We have compile all the files, which are used in top level file.
Can you attach complete project?
Anand
- OMaga7 years ago
All files in zipped folder.
- OMaga7 years ago
Update, I noticed that there was no subfile for the LCELL component, so I've created one that is essentially an and gate.
LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY LCELL IS PORT ( a_in : IN STD_LOGIC; a_out : OUT STD_LOGIC ); END LCELL; ARCHITECTURE Behavior OF LCELL IS SIGNAL delayedpulse: STD_LOGIC; SIGNAL KEY: STD_LOGIC; BEGIN KEY <= '1'; delayedpulse <= a_in AND KEY; a_out <= delayedpulse; END Behavior;I added this to the project, however, I still receive the "component instance LCELL not bound" error
Hi ,
Anand
