EastGun-A
3 years agostratix 10dx PCIe gold finger recognition
Hello, thank you for always helping me. I use 'LSPCI' to check the PCIE device, but the PCIE of the FPGA is not recognized. While designing the FPGA logic, slack comes out as a negative value. Cou...
- 3 years ago
I am not sure what you had modified.
But I suggest you to look back the design, ensure all pin is connected in what the IP suggested.
Wincent_Intel
Wincent_Altera
3 years agoHi,
but TLP communicated normally before the fix.
The sof file was also programmed normally. (both before and after TLP correction)
>> do you means the TLP and sof file able to run in good condition before you modifiying the design example ?
Wincent_Intel
- EastGun-A3 years ago
yeah, it's right!
'lspci' figured out the "PCIe device" before modifying.
It is not recognized after modification. (slack is changed positive 0.03 to negative -88)
I programmed the sof file in the same process.
