stratix 10dx PCIe gold finger recognition
- 3 years ago
I am not sure what you had modified.
But I suggest you to look back the design, ensure all pin is connected in what the IP suggested.
Wincent_Intel
I changed the sof file to pof and proceeded with programming.
Well, while modifying the pcie example, slack got -88, so I wonder if this is why it is not recognized.
Although the link up has been completed, I have confirmed that the completion TLP of the configuration read does not return, so I wonder if it is a problem caused by slack (setup/hold time violation).
- Do the error happen while you program the .sof file as well ?
- Do the TLP configuration read able to complete without modifiying anything ?
- What is the LTSSM status ? is it in L0 stage ?
- Can you show the printscreen error of slack -88 ?
Wincent_Intel
- EastGun-A3 years ago
Well, I couldn't attach the file now (I haven't received the detailed LTSSM status and file yet), but TLP communicated normally before the fix.
The sof file was also programmed normally. (both before and after TLP correction)thank you always.
