13 years agoSome help needed connecting NIOS-II with ISP1362 chip
Hello, I'm pretty new to embedded programming. I want to use the DE2 board as mp3 player, using the USB as input for my mp3 files. So I need an USB host controller. Since the SLS hc controlle...
8 years agoHey im hanging on the same problem. ChipID is 0 and also if i write and then read from the HcScratch register my value is not set. Did you found any solution on that?
