17 years agoSoftware problem - Character LCD core HAL
Hi all, I'm working with the DE2 board and I have built a system which includes the charater LCD core that came with the university program IP cores. According to the NIOS II software developm...
17 years agoHiya!
when the system is being generated in the SOPC builder, check the messages that are generated... If it is including the cores in the system, it should be visible in your sys lib properties... Also, i'm not sure whether it makes a difference or not but try using the core that comes built in with the SOPC builder... --- Quote Start --- I have built a system which includes the charater LCD core that came with the university program IP cores --- Quote End ---
