AVija7
6 years agoSir, I would like to design a SFPDP module that receive parallel data from F/o module . This is a part of a recorder. My question is how to proceed with Stratix IV board? Can i use ALTGX Transceiver for that? If so please do mention challenges.
Thanks in advance
AVija7
6 years agoSir,
As you mentioned i done with single channel now, I was able to {Frame, encode,serialize in Transmitter} and{De-serialize, decode, de-frame the data in Receiver} correctly in simulation. But the problem arise when i'm using the hardware setup.
1.I'm using signal tap II analyzer for watching the signal real time
2. There are two FPGA inside my custom board and using one as TX and one as RX
3. I have done the sample code where i was using 8 bit data with control code K28.5
But i'm not able to receive the data properly. How to resolve the problem??
If there is any design example file kindly share here
Thanks in advance
Arya vijayan
- CheepinC_altera6 years ago
Hi, As I understand it, you are sending data between two SIV devices and seems to observe issue at the RX output. Would you mind to further elaborate on the issue observation when you referred to RX unable to received the data correctly? Some screenshots will be helpful for understanding. Thank you. Best regards, Chee Pin
