AVija7
6 years agoSir, I would like to design a SFPDP module that receive parallel data from F/o module . This is a part of a recorder. My question is how to proceed with Stratix IV board? Can i use ALTGX Transceiver for that? If so please do mention challenges.
Thanks in advance
AVija7
6 years agoWhen i was using ALTGX,offset cancellation is automatically enabled and there we need this dynamic reconfiguration right? That's why i have created ALTGX_RECONFIG Instance.
Well, i can summarize my procedure like this
- By using ALTGX i have developed a transceiver setup with 650 Mbps with 4 channel and 16 bit wide , also the protocol i have used here is XAUI
- I have a 16 bit input data on each channel and i have to serialize encode and transmit on transmit side
- Similarly the opposite have to be done in the receiver side of transceiver
- In between the transmission and reception of data i have to frame and de-frame the data using user logic
- This whole design is to design SFPDP (Serial front panel data port)
Problems facing
- Developed the transceiver setup but i'm not able to de-serialize back the serialized output data from the transmitter by loop backing the data in user logic
- Don't have much idea about dynamic reconfiguration using ALTGX_RECONFIG
- The explanation available in the user guide is bit confusing
