17 years agoSimple Verilog Question
Hello I am trying to make a simple multiplexer on the de2-70. I know there are many ways to do this but I was wondering why the following code does not do the task. Task: Read switch 17 if switch ...
17 years agoAs pletz correctly wrote you did a mistake in defining your wires and the clock.
these mistakes didn't have something to do with dual purpose pins you mentioned with your link. in fact the error message you have posted clearly states that your clock array can not place all array elements at that single pin of your device. with the code posted from pletz your module should work.
