17 years agoSimple Verilog Question
Hello I am trying to make a simple multiplexer on the de2-70. I know there are many ways to do this but I was wondering why the following code does not do the task. Task: Read switch 17 if switch ...
17 years ago --- Quote Start --- Thanks for the help Those examples worked very well. I assume you say using the clock to avoid glitches with the timing of the gates. I tried to write the code to use the 50MHz clk on the board for the clock to the mux so I wrote this code segment from the example you added.. module Lab1 (iCLK_50, iSW, oLEDR); input [17:0]iSW, iCLK_50; output [7:0]oLEDR; reg[7:0]LedReg; wire oLEDR; always @ (posedge iCLK_50) LedReg <= iSW[17] ? iSW[15:8] : iSW[7:0]; assign oLEDR = LedReg; endmodule but now I am getting the following error. Error: Can't place multiple pins assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[1] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[2] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[3] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[4] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[5] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[6] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[7] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[8] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[9] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[10] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[11] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[12] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[13] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[14] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[15] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[16] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[17] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) Info: Pin iCLK_50[0] is assigned to pin location Pin_AD15 (IOC_X49_Y0_N1) I had a simlar error with the switch number 7 on the DE2-70 board and fixed it from this post: http://www.alteraforum.com/forum/showthread.php?t=5851&gsa_pos=1&wt.oss_r=1&wt.oss=de2-70%20multiple%20pin%20assignment%20error (http://www.alteraforum.com/forum/showthread.php?t=5851&gsa_pos=1&wt.oss_r=1&wt.oss=de2-70%20multiple%20pin%20assignment%20error) but it is not working in this case. I was wondering if anyone sees what I did wrong. Thanks for the help! --- Quote End --- Hi, I have modified your source code. Look into the comments . module Lab1 (iCLK_50, iSW, oLEDR); input [17:0]iSW; input iCLK_50; output [7:0]oLEDR; reg[7:0]LedReg; wire [7:0] oLEDR; always @ (posedge iCLK_50) LedReg <= iSW[17] ? iSW[15:8] : iSW[7:0]; assign oLEDR = LedReg; endmodule // input [17:0]iSW, input iCLK_50; you specfied your clock input as 18-bit vector // wire oLEDR; you defined a single bit wire but assignment was a vector LedReg[7:0] // What about iSW[16] ? Kind regards Gerd
