17 years agoSimple Verilog Question
Hello I am trying to make a simple multiplexer on the de2-70. I know there are many ways to do this but I was wondering why the following code does not do the task. Task: Read switch 17 if switch ...
17 years agosanmaro ist correct, this is a pitfall and sometimes hard to find but if you write it as suggested
assign oLEDR = iSW[17] ? iSW[15:8] : iSW[7:0]; then is clear and easy to read and of course to check. but be aware of glitches as you only do combinatorical logic if possible better use a clock and registers for the output. declare oLEDR as a wire, add a register like reg [7:0] MyReg; always @ ( posedge MyClock ) MyReg <= iSW[17] ? iSW[15:8] : iSW[7:0]; and then assign the register to the output assign oLEDR = MyReg;
