17 years agoSimple Verilog Question
Hello I am trying to make a simple multiplexer on the de2-70. I know there are many ways to do this but I was wondering why the following code does not do the task. Task: Read switch 17 if switch ...
17 years agoHi Blue1440,
--- Quote Start --- I know this is simple...but I am really just confused on the vector sintax. I would like to understand it better, so if anyone can fix the code or point me to a good tutorial on vector notation I would really appreciate it. --- Quote End --- In the Verilog code that you write, you use the Verilog "&" and "|" bitwise operators. They operate on corresponding bits in the vector(s) of the two operands, starting from the least significant bit. When you write:
~iSW&iSW
this means that the first vector is ~iSW[17] and the second vector is iSW[7:0]. When doing bitwise "&" it means that ~iSW[17] is ANDed ONLY with bit iSW[0]. So you should eather make a bit extension to your condition for switch 17 for example as:
{~iSW,~iSW, ~iSW,~iSW,~iSW,~iSW,~iSW,~iSW}&iSW
or better use the inline if-then-else "? :" construct as given below:
module Lab1 (iSW, oLEDR);
input iSW;
output oLEDR;
assign oLEDR = iSW ? iSW : iSW;
endmodule
Hope this helps!
