16 years agoSimple Socket Server on DE2 w/Davicom DM9000A
updated.
Altera's Simple Socket Server demo running on a DE2 board with the Davicom DM9000a driver. here it is....zipped downloaded project source for sss on the de2 board. download link currently unavailable. Includes: - Hardware design (TLD in schematic block diagram format) - Programmable .SOF (time-limited, as developed in Quartus Web Edition v9.2) - SOPC builder system file - DM9000A driver for Nichestack TCP/IP stack / Altera HAL environment (courtesy of Columbia Uni) - Simple socket server software Simply... - (1) Download the .SOF in Quartus Programmer - (2) Open the software workspace in the "/software" directory in Nios II Build Tools (Eclipse IDE) - (3) Open Run >> Run Configurations. Delete the current configuration. Create a new launch configuration selecting the project name under the Project Tab. Ensure your DE2 board is plugged into USB. Check the target connection tab and make sure it is present. - (4) Plug into your local network (DHCP is enabled, or app will default to static IP) - (5) View the Nios II console for debugging information (via JTAG UART) - (6) Telnet into the board from a pc: telnet <ip address> 30. Enjoy the simple socket server demo from Altera! Questions/comments? Fire away below!98 Replies
--- Quote Start --- try to use proxy server.i did it and downloaded successfully. --- Quote End --- @xiongxin18 (http://www.alteraforum.com/forum/member.php?u=26259) Can you plz Send me the Dm9000A IP Core And hal Driver Used in simple socket server on de2 w/davicom dm9000a at [email protected] tried many times by cant be able to download....its urgent
--- Quote Start --- @xiongxin18 (http://www.alteraforum.com/forum/member.php?u=26259) Can you plz Send me the Dm9000A IP Core And hal Driver Used in simple socket server on de2 w/davicom dm9000a at [email protected] tried many times by cant be able to download....its urgent --- Quote End --- @xiongxin18 (http://www.alteraforum.com/forum/member.php?u=26259) Your Email Is empty
i am waiting for the google Code website
Have just setup Google Code hosting for the DE2 socket server project.
http://code.google.com/p/de2ethernet/ Will upload the initial development release in the next few days...after some additional testing. - Altera_Forum
--- Quote Start --- Everithing went ok for me until I downloaded the software to the FPGA, I get this error on NIOS Terminal.
I have quartus II 9.0 whit a valid license. Can't somebody help me? Jairo --- Quote End --- I had this problem also, I had selected the Terasic dm9000a IP in sopc rather than the dm9000a provided with the project. I just copied the dm900a folder and the dm900a.vhd and tcl files to my projects folder. JTInterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prepped 0 interfaces, initializing... inet startup error: unable to find any working interfaces panic: IP dtrap - needs breakpoin - Altera_Forum
my email is [email protected], would you like to show me the zip file? I've met some problem with my project, so I'd like to have yours as a verification.
I also need the DM9000A for the SOPC Builder. [email protected] Thanks! - Altera_Forum
if you don't mind, please send me your zip file! [email protected] - Altera_Forum
hi,
please to me too [email protected] - Altera_Forum
i Will Share the Simplesocketserver.zip file today.Probably Megaupload link.So you guyz have wait till 12 PM
Regards Hasil86
