16 years agoSimple Socket Server on DE2 w/Davicom DM9000A
updated. Altera's Simple Socket Server demo running on a DE2 board with the Davicom DM9000a driver. here it is....zipped downloaded project source for sss on the de2 board. download link c...
13 years agoHi 8strings,
I've not thought this through. I'm not sure about the patch. I think you new create new subject about this. The connections issue I'm not really familiar with it in de2. I've tried before to work on it, but I failed on that one. The problem with de2 board now it's not up to date with the new Q II and Nios II. For example, dm9000a in sopc v 7.2 and later, is not supported. In addition, older and closed site www.nioswiki.com has de2 templates which is not available on any cd with any device, and after they closed it the didn't move the data to the new site www.alterawiki.com. If you are going through this I suggest you look to get three things first: make sure to compile hardware part in QII successfully. Even with small unconstrained paths. Second: Check the dm9000a does it need license? I suggest you check with their company directly try to call them "http://www.davicom.com.tw/" Third: You need an application/software part in Nios II, which I struggled too long searching for it, but I couldn't find. There are some templates on NiosII like " simple socket server" and " Web server", but I'm not sure they work directly
