16 years agoSimple Socket Server on DE2 w/Davicom DM9000A
updated. Altera's Simple Socket Server demo running on a DE2 board with the Davicom DM9000a driver. here it is....zipped downloaded project source for sss on the de2 board. download link c...
15 years agoHi Guys,
I follow everything from your suggestion. After i run it, the following message appear at my console and it look good. But when i telnet from my PC to the board, it doesnt work. I direct connect UTP LAN cable from my PC to the board. Can someone advise me? Thanks. This software project uses an unlicensed version of the NicheSta=============== Software License Reminder ================ This software project uses an unlicensed version of the NicheStack TCP/IP Network Stack - Nios II Edition. If you want to ship resulting object code in your product, you must purchase a license for this software from Altera. For information go to: "http://www.altera.com/nichestack" ===================================================== InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. Your Ethernet MAC address is 00:07:ed:ff:92:78 Static IP Address is 192.168.1.234 prepped 1 interface, initializing... dm9ka_init Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) mctest init called IP address of et1 : 192.168.1.234 Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4)
