16 years agoSimple Socket Server on DE2 w/Davicom DM9000A
updated. Altera's Simple Socket Server demo running on a DE2 board with the Davicom DM9000a driver. here it is....zipped downloaded project source for sss on the de2 board. download link c...
15 years agoHi tnndesign,
Thanks for uploading this solution for DE2, However I have a couple of questions regarding your design. 1) Your design works fine as it is, now after I recompile the design (no changes to anything), just regenerating bsp and build the libraries, I experience problems. The simple socket server starts (establishes connection, assigns IP, and even the LED's start blinking) and then for some it reason abruptly stops(cannot ping, cannot establish connection to server, LED's stop blinking). 2) I noticed that the driver in the example( VOIP pdf) was developed for uclinux, how did you transfer it to Ucos? what changes did you make? 3) You had earlier said there was a problem you had experienced regarding some directories, maybe I am also experiencing the same problem, could you elaborate on that? 4) I have a feeling that my compilation error could be because of version compatibility ( I am using quartus 9.0 and do not have any SP updates). So could you update a backward's compatible project archive? and lastly 5) I noticed that you have only attached a time limited sof file, I couldnt find any opencores component, have you used any? or is it because that u only have a web edition?
