16 years agoSimple Socket Server on DE2 w/Davicom DM9000A
updated. Altera's Simple Socket Server demo running on a DE2 board with the Davicom DM9000a driver. here it is....zipped downloaded project source for sss on the de2 board. download link c...
16 years agoOk When i open IDE Eclipse, i select a workspace ( i created a new workspace) when the platform opens i choose File -> new -> Nios II Aplication and BSP from Template. Then i select the sopcinfo file , which was in the zip-order and choose an Projectname (ethernetconnection) and choose simple socket server and 'finish'. then run -> run configurations-> NIOS II HARDware-> new configuration and selcet the Projectname( ethernetconnection). but under Elf File name there is no object which you can select, there is only an empty field. so i cant run the project. have i forgotten something? or how can i solve this problem?
