16 years agoSimple Socket Server on DE2 w/Davicom DM9000A
updated. Altera's Simple Socket Server demo running on a DE2 board with the Davicom DM9000a driver. here it is....zipped downloaded project source for sss on the de2 board. download link c...
16 years agoHi Catmoe. Have just revised the instructions. (See above).
Make sure you follow Step (3), otherwise you may experience failure due to mismatched system timestamp/ID. Also, if you're not using DHCP, you can disable in the BSP settings for Nichestack. But the app should auto-default to a static IP anyway, so this shouldn't be a problem. If all goes well, you should see in the console the program being loaded into SDRAM, verified and then in the Nios II console on the right of your screen, you should see the Nichestack initialisation and the debug output from the socket server program. Let me know how you get on with that!
