16 years agoSimple Socket Server on DE2 w/Davicom DM9000A
updated. Altera's Simple Socket Server demo running on a DE2 board with the Davicom DM9000a driver. here it is....zipped downloaded project source for sss on the de2 board. download link c...
16 years agoAre you running DHCP to a switch?...or, better still, to a DHCP server that you have access to? That way you can see (or not) the packets that your board is generating. Of course, if you are statically assigning IPs then that doesn't apply.
Simply hangs doesn't really help me to help you much. What happens if you Debug the code and step through it to see where it's actually hanging? So...throw me some more info and I'll see if I can help. Cheers, and Good luck... --slacker
