Setting Up a remote FPGA Farm using DSEII with SSH
Hi, thanks for your response!
I entered my IPv4 Address in additional arguments as "--host 127.0.0.1" and it worked!
But now I'm having another issue, I would be happy if you could help me with this one too:
Info: Processing started: Wed Sep 20 14:28:04 2023
Info: Resolved host: 127.0.0.1 to IP address: 127.0.0.1.
Traceback (most recent call last):
File "d:\programas\quartus\quartus\common\python\lib\site-packages\peewee.py", line 3129, in execute_sql
cursor.execute(sql, params or ())
sqlite3.OperationalError: database is locked
During handling of the above exception, another exception occurred:
File "<string>", line 22, in <module>
File "explorer.py", line 1918, in main
File "explorer.py", line 1790, in main_impl
File "explorer.py", line 391, in run
File "rcomp.py", line 193, in clear
File "rcomp_db.py", line 410, in init
File "rcomp_db.py", line 437, in clear
File "d:\programas\quartus\quartus\common\python\lib\site-packages\peewee.py", line 3321, in drop_tables
model.drop_table(**kwargs)
File "d:\programas\quartus\quartus\common\python\lib\site-packages\peewee.py", line 6657, in drop_table
cls._schema.drop_all(safe, drop_sequences, **options)
File "d:\programas\quartus\quartus\common\python\lib\site-packages\peewee.py", line 5785, in drop_all
self.drop_table(safe, **options)
File "d:\programas\quartus\quartus\common\python\lib\site-packages\peewee.py", line 5658, in drop_table
self.database.execute(self._drop_table(safe=safe, **options))
File "d:\programas\quartus\quartus\common\python\lib\site-packages\peewee.py", line 3142, in execute
return self.execute_sql(sql, params, commit=commit)
File "d:\programas\quartus\quartus\common\python\lib\site-packages\peewee.py", line 3136, in execute_sql
self.commit()
File "d:\programas\quartus\quartus\common\python\lib\site-packages\peewee.py", line 2902, in __exit__
reraise(new_type, new_type(exc_value, *exc_args), traceback)
File "d:\programas\quartus\quartus\common\python\lib\site-packages\peewee.py", line 185, in reraise
raise value.with_traceback(tb)
peewee.OperationalError: database is locked
Design Space Explorer finished
What could cause this?
